Dashboard shows battery state of charge at 43% and alarm page shows 52%, I cannot see why there is so much difference. Any help appreciated please
The values come from two different devices. One might be a shunt, the other the Multiplus. Set the system to use thr shunt and hide the other battery measurments
Many thanks will try and find these settings and post if I have success.
Settings / System Setup / Batteries / Battery Monitor will set the battery monitor to be shown as the main value.
Settings / System Setup / Batteries / Battery Measurements will set which battery monitors are visible.
Didnt notice that its an alarm page and not an advanced widget.
Delete the alarm and create a new one for the battery monitor that you want to use
Thank you for the assistance, I have now done this.
