Dash board information
Battery state of charge does not display correctly.
Shows 95% on dash board, actual 67%
Is GEORGE set as battery monitor ( presuming this is the data you want for %)
Above is screenshot from my system settings, depending on what device i select for battery monitor will affect information within battery box on dashboard
Set to Victron
(attachments)
It really should be set to the solar md.
DVCC should be on.
Did you follow their guide?
Had a consultant do the ESS setup.
Will change as you suggest.
Regards
Changed settings, now showing correctly.
