MultiPlus Compact 12/800 + 12/1200 cascade in a Transit Custom – build and rationale
Hello everyone,
I am currently planning/building a somewhat unusual 230 V system in a Ford Transit Custom and would like to hear about your experience with, or get a technical assessment of, combining two MultiPlus Compact units.
I am aware that connecting the AC output of one MultiPlus to the AC input of another MultiPlus is not a conventional Victron standard topology. In my case, however, the cascade has been chosen deliberately because I have two separate 12 V battery systems and, at the same time, want to limit the maximum load on the vehicle side through the hardware.
Basic layout
Vehicle side:
150 A smart alternator
→ Starter battery
→ Victron MultiPlus Compact 12/800/35-16
→ 230 V AC
→ AC input of the MultiPlus Compact 12/1200/50-16
Living-area side:
2 × 12 V / 140 Ah lead-acid batteries in parallel, i.e. 280 Ah nominal
→ MultiPlus Compact 12/1200/50-16
→ 230 V loads
Solar will later be added to the vehicle roof, connected via an MPPT directly to the living-area batteries.
One of the largest planned loads is an inverter-controlled roof air conditioner with approximately 3.6 kW of cooling capacity and approximately 1.3 kW of rated electrical consumption.
Why is the 12/800 on the vehicle side?
The 12/800 is deliberately intended to form the interface between the vehicle and the living-area system.
The main reason is the physical power limit.
I do not want the living-area system to be able to draw theoretically unlimited power from the starter battery and alternator. The 800 limits the transferable power through its hardware alone.
At around 650–700 W of AC output power, the additional load on the vehicle’s 12 V side is roughly in the region of 55–60 A, depending on battery voltage and efficiency.
This means that the 1200 on the living-area side cannot suddenly demand 80, 100 or even more amps from the vehicle side.
Naturally, at a hot idle the alternator may in some circumstances supply less than the vehicle’s own consumption plus the MultiPlus require. The starter battery would then temporarily provide part of the power. After installation, I intend to test this behaviour under real-world conditions using a DC current clamp and vehicle diagnostics.
The 800 should otherwise work as “dumbly” as possible:
- install the latest firmware
- configure it fully once
- control the remote input via a relay connected to the ignition positive
- no further operation during normal use thereafter
When the ignition is active, the 800 is enabled. Outside engine operation, the ignition positive on this vehicle is only live in a few brief comfort-related situations. Given the MultiPlus’s very low no-load consumption, this is acceptable for my application.
Why is the 12/1200 on the living-area side?
The 1200 is intended to be the actual “system manager” for the living area.
It is connected directly to the 280 Ah living-area batteries and handles:
- supplying the 230 V loads
- charging the living-area batteries
- PowerAssist
- limiting the AC power drawn from the upstream 800
- later, control and monitoring via a VE.Bus Smart Dongle
While driving, the 1200’s AC input current will initially be limited to around 3.4 A.
At 230 V, this corresponds to a maximum of approximately 780 VA and is therefore deliberately close to the power rating of the upstream 800.
If a load requires more than the 800 can provide, the 1200 is intended to supply the difference from the living-area battery via PowerAssist.
Example:
The roof air conditioner requires approximately 1.3 kW electrically.
The 800 supplies a limited portion from the vehicle side.
The 1200 supplements the missing portion from the living-area battery.
This prevents the starter battery/alternator side from being loaded with the air conditioner’s full power requirement.
The 3.4 A is initially a test value. If it turns out that the 800 permanently reduces its output thermally or becomes unstable at high ambient temperatures, the limit could, for example, be reduced to 3.0–3.2 A.
Solar
Solar will later be connected directly to the living-area batteries.
While driving, this would theoretically provide three energy paths simultaneously:
Alternator → 800 → AC → 1200
Solar → MPPT → living-area battery
Living-area battery → 1200 PowerAssist
This means that, particularly with the air conditioner, no single source has to handle the entire load.
Shore power
Shore power is to be fed into the AC input of the 800.
This gives:
Shore power
→ 800
→ AC output
→ 1200
→ loads
The 800 can charge its own starter battery while the 1200 charges the living-area batteries.
Both MultiPlus Compact units have a 16 A transfer path, so when shore power is available, the devices do not have to invert the entire load.
With actual shore power, the 1200’s AC input limit can of course be set correspondingly higher. The approximately 3.4 A is primarily intended for operation downstream of the 800 while driving.
That is precisely why I would rather use the VE.Bus Smart Dongle on the 1200: the AC input limit, PowerAssist and living-area battery are the relevant parameters there.
Why not simply use a larger DC/DC charger?
A conventional DC/DC charger would of course be the more standard solution.
However, AC coupling offers me several interesting features:
1. The vehicle side is power-limited through the 800’s hardware.
2. The 1200 can use PowerAssist.
3. The starter and living-area batteries remain electrically separate DC systems.
4. With shore power, both battery systems can be charged through their respective MultiPlus chargers.
5. The energy source at the 1200’s AC input can change without anything having to change on the actual living-area side.
6. The living-area battery deliberately serves as a large buffer for briefly higher loads.
Critical point: MultiPlus → MultiPlus
This is the part where I am particularly interested in other users’ experience.
I understand that using one MultiPlus as the AC source for a second MultiPlus with PowerAssist is not a typical or officially standard Victron system design.
For this reason, before putting the system into productive use, I particularly want to test the following situations:
- synchronisation of the 1200 to the 800
- behaviour during rapid load changes
- PowerAssist under high load
- behaviour when the 800 undergoes thermal derating
- switching the vehicle-side MultiPlus off and back on
- loss and restoration of the AC input
- switching between inverter operation and shore power
- low state of charge of the living-area batteries
- hot engine / hot alternator at idle
- possible control oscillations in which the 1200 repeatedly accepts and rejects the source
The two devices will not be connected in parallel via VE.Bus. This is solely an AC cascade with separate battery banks.
If anyone has already operated a MultiPlus or Quattro as a limited AC source upstream of a second MultiPlus with PowerAssist, I would be particularly interested in experiences regarding stability, synchronisation and any settings that may be required.
Ultimately, my goal is:
Driving: the alternator automatically supports the living-area system.
Stationary: solar takes over as far as possible.
High load: the living-area battery provides buffering via PowerAssist.
Shore power: both battery systems are charged automatically.
So the unusual part has been chosen deliberately – mainly to maintain a hard power limit between the vehicle and living-area sides without having to forgo PowerAssist on the load side.
