Hello, I have built a Victron system at home (Belgium).
It consists of
- Victron three-phase meter installed after the “smart” meter.
- 3x MultiPlus 5000/70
- 2x Lynx Distributor
- 5x Pylontech US5000
- 1x Cerbo GX + Touch 50
- PV system: 3x SMA Sunny Boy (2012)
I am actually looking for a guide to help me configure the settings correctly.
The PV system is distributed across the three phases and is connected behind the grid meter.
The ESS is also distributed across the three phases and connected behind the grid meter.
I have a flexible contract with ENGIE, which gives me three different tariffs per day, with different prices at set times. At weekends, I have two tariffs (the most expensive tariff does not apply then).
I would like to achieve the following:
When there is no sunshine, I want to use the battery during tariff 1 if the battery’s SOC is above 70% and more than 1000 W is being drawn from the grid.
When there is sunshine and consumption is > 1 kW during tariff 1, I want to switch on the battery.
You can understand that I want to expand this with many more scenarios. But I don’t think I’m the only one. Has anyone here done something like this before? And if so, how?
Kind regards,
Frans
