Converting from Centaur charger to Multiplus Compact
Hi All
My current setup has 3agm batteries charged by a victron centaur charger & inverted by a xantrex freedomx. The xantrex has given up the ghost, so I picked up a Multiplus Compact Intverter-Charger to replace both units. The centaur has 3 positive battery lugs, while the multiplus only has one battery positive lug. Do I simply hook up all three batteries to the single lug?
Thanks
Mark
yes. Remember to include a fuse of suitable rating.Edit - the compact has an internal fuse, so a disconnect switch should be used.
