When I plug my van in to the mains My MultiPlus Compact inverter is turning off after the battery is fully charge. If I switch it off and then back on it stays on until the battery reaches full charge again.
What battery do you have?
What are the charger settings of the MultiPlus?
@Ducati996996 The original post talked about a multiplus but the photos show the information for an Orion. The Orion is switched off but what about the multiplus?
Orion shows input voltage but no output voltage… Seems like the battery is tripping at full charge.
That would also explain the inverter switching off.
Lower the charge voltage. The bms is having a hard time.
Sorry I’m not very technical with this sort of thing. Where do I adjust the charge voltage?
I see roamer claim integration with Victron and have guides. What battery model do you have?
And also what VA is you inverter?
For the inverter you need an mk3 to usb adaptor and Victron connect.
The orion can be adjusted with Bluetooth settings in battery settings.
