MultiPlus 12/3000/120-16
I have a MultiPlus 12/3000/120-16 in my system.
It only have 2 port to connect different controller.
I have a Cerbon and a Multi control installed.
Is there any way so I can connect it to VRM or the Victron connect app?…
Now I have to disconnect the Multi control and connect the MK3-USB-C and work on it on my laptop…
If you have the Cerbo it just needs to be connected to the internet. What do you currently use for internet?
I have a 5g router that’s the Cerbo is connected to…
Can I do changes on the Multiplus that way?
Yes you can but only over the vrm. Where you download the configuration then upload it again after modification. So you need access to the vrm account it is registered to.
You will need ve configure to do this as well not victron connect.
