Connect BMV 602 to Windows 11 PC/BMV Reader via USB
I have the BMV 602 and Victron lead with a RS232 serial plug on the end.
The last time I used it I had a PC with a serial port. I am now trying to connect to a Windows 11 PC. I have used a Ugreen serial to USB adapter with Prolific PL2303GT chipset to convert a serial AIS output into a USB input and it works well.
But the same device doesn’t work with the BMV 602 serial lead.
I have changed the Baud rate to 19200 as in the Victron BMV-60xS Text Protocol datasheet.
In the BMV Version 1.4.2.0, which seems to be the latest, I get a green com port but a red Disconnected.
So grateful for any pointers??
Solved. I uninstalled the latest version of BMV Reader and installed the original 2008 version.
