Folks,
I have a configuration issue with a new install.
Equipment:
Multiplus 12/300, Lynx BMS, 2 Lynx distributors, Cerbo GX, four 200 amp Victron Lithium smart batteries non NG. Not networked, MPPT 150/45 and 2 24v/12v 30a. chargers.
Issue: batteries , Lynx, and BMS were installed 9/22/25. All worked fine. Xantrex inverter charger stopped working and was replaced Sunday 9/28/25 with a Multiplus and CerboGX.
Today 10/2/25 customer sent image of the BMS showing ATC/ATD error and charger showing low battery voltage. Batteries checked out 100% via Bluetooth.
Went into VE.Bus configure to set charger to “Victron lithium on BMS”, accepted presets.
Returned VE.Bus to CerboGX. Shortly after the BMS reduced power to 9.5v while the batteries were showing 13.8. After a little while the BMS shut down output completely. I put the BMS on standby, restarted, everything came back up and the ATC/ATD error went away.
Now I went back into the Multiplus to set the 800 amp capacity and now the inverter is showing low battery voltage and the inverter is in standby pass through mode.
I’m sure the “configured for VE.Bus BMS” shouldn’t be selected or is that just for NG batteries?
The solar and 24/12 chargers are not VE. Direct connoted to each other or the GX. There are no connections on the BMS ATC/ATD outputs.
The boat is also in transit and not available physically
Is there a way of networking the solar and 24v/12v chargers via Bluetooth?
I’m not sure if this is a networking issue with the Cerbo or a configuration issue or both.
Any ideas?
