I have a lynx BMS connected to a cerbo GX via the CAN bus, and the cerboGX is also connected to my Multiplus through VE.Direct.
These are the connections the multiplus has:
- the VE.direct connection to the cerboGx
- the DC connection to the BMS (2x2 50mm2 wires)
- the AC in put and two AC output
If I power up the system, the multiplus shows a low battery alert, and the associated red LED turns on.
I checked with a voltmeter that there was power in my big DC wires, and there is (13.15V). My lithium batteries are full
I also connected to the Multiplus with my computer using a MK3 and I can see the multimplus properly detected it was dealing with a lithium BMS. the low battery voltage alarm is set way below 13.15V
Lastly I checked the manual which states that the battery sensor connection is optional.
Am I missing something here? How can I get the inverter to stop complaining ?
