Compatibility Victron and SMA inverters?
Does anyone know if there is an option to combine a victron multiplus II and some SMA inverters in one system? I.e., if there is a controller that can measure the energy flow at the grid connection point behind the electricity meter and thus control the battery inverter either to charge or to feed? At the moment I have a sunny home manager 2.0 , 3 solar inverters and one AC battery inverter from SMA, but I want to extend this with a Victron Multiplus II 48/5000/70 plus a 16 S LFP battery pack. The sunny home manager clearly canot manage the victron - but can another controller?
Sma does not have zero feed in support on the victron side.
It will basically produce at full power and feed whatever.
What kind of control do you want to have over the Victron and with what system? There are many options like modbus, home assistant, node red.
Its supposed to be Node RED, as this is part of Venus OS. As I have discussed it with others, the way to control the victron inverter could be derived from the SMA system. The data from the grid connection point are available in the MODBUS registers of the SMA inverters, such as line voltage and current per phase, so the power situation also is known. If I can use these variables as inputs in Node RED, divide let’s say by 2 and send them to the inverter, as if it came from a smart meter, then it possibly should be able to charge / discharge its battery also by half of the full requirement. As it “steals” now energy from mains the SMA battery inverter also gets only 50% for charging. Its than the same vice versa.
I only just need to learn how I can read modbus TCP from the SMA device, calculate new values and send them to the victron inverter using Node RED.
Hello, you can use the Sunny Home Manager to control it. There is a script that can read the Sunny Home Manager and emulate an ET340 on the GX. Then you can also achieve zero feed-in with the battery. It works well for me.
Alternative to ET340 - SMA Home Manager 2.0 - VictronEnergy
Mfg
TK1
Hallo Thorsten,
Ich denke wir können deutsch reden… …
Ja, schade, dass es 3 Monate gedauert hat bis du geantwortet hast! Inzwischen habe ich mir selber eine Regelung gebaut, die über NodeRed geht und Automationsfunktionen des HomeAssistant nutzt. War ein bisschen aufwändig, aber es läuft jetzt auch - mit Nulleinspeisung natürlich.
Trotzdem danke! Kann ich ja vielleicht doch irgendwann mal nutzen.
GrĂĽĂźe
Axel
Hallo,
ich habe deine Frage erst dann gesehen. Ich bin noch nicht so lange hier angemeldet. Es gibt bei dem Skript leider ein Problem mit der neuen UI. Da wird das Netz nicht angezeigt.
Wird denn mit deiner Lösung alles angezeigt?
Mfg
Thorsten
Hi Thorsten,
meine “Lösung” ist vom neuen UI nicht betroffen. Die ist ziemlich “home made” und somit auch nicht so einfach auf andere Systemkonfigurationen anwendbar. Ich habe schon seit ich hier vor 11 Jahren das ganze Haus genaralüberholt habe den KNX Bus “drin”. Und darüber läuft auch der gesamte Stromzählerbetrieb, incl. Datenübernahme vom EVU Hauszähler. Deshalb weiß ich den aktuellen Leistungswert am Stromzähler, und alle Verbräuche. Die addiere ich einfach, die PV Leistung wird davon abgezogen (die habe ich auf Umwegen über den HA auch auf KNX gebracht), und das ergibt dann erstmal meinen “Roh-Saldo”, der je nach PV Leistung positiv oder negativ sein kann. Über einen einfachen Prozentsteller berechne ich daraus dann den Steuerwert für das Victron ESS (externer Modus ist aktiv), und dann wird die zweite Batterie entweder geladen oder entladen. Für den Sunny Home Manager ist das nichts weiter wie ein weiterer Verbraucher - der muss ja letztlich die Differenz am Vermittlungspunkt berechnen und ausgleichen, und der macht das auch sehr gut. Der SunnyBoy Storage 6.0 ändert seine Leistung übrigens wesentlich schneller als der Victron. Anscheinend gab es vor 4 Jahren die Vorgabe “Delta P < 400 W / sec” noch nicht.
Für mein System nutze ich die Modbus-, die Victron- und die SunSpec Integration. Die können mir natürlich bei Updates auch die Suppe versalzen. Bisher läuft es aber super.
GruĂź
Axel
