Circuit breaker for Charging Station
For my Victron Charging Station, what circuit breaker do I need?
Specs say they recommend “Type B”, but I can barely find something like this. I was searching for “RCBO 32A Type B” (single-phase system)
Question1: is “Type B” needed?
Question2: can you share a recommendation for actual breaker?
Search for RCBO B32, plenty to find on google depending on your region ofcourse
Yes, but the results are “Type A”; from what I understand, I need “B curve” (as in B32 above), but also “Type: B” (which handles potential DC leakage). Maybe I will get some actual models (if this forum allows it).
Try to search for B-EV. I used below RCD in my installation with a separate 32A group before each EVCS.
I gave up trying to find a combo unit.
RCD: RCCB HPFI afbryder 4P, 40A, B-EV, 30 mA, AC/DC - Acti9 Schneider Electric ‒ WATTOO.DK
32A Fuse: Acti9 Schneider Electric IC60N – Automatsikring, 32A, 3P+N, 6kA, C-karakteristik, 4 modul, 72 mm ‒ WATTOO.DK
