Charger settings of mastervolt combimaster with Victron smart_lithium
I’m integrating the inverter /charger mastervolt combimaster 12v/3000W-160 ah 120 unit with my new 300 ah lithium Victron battery. What charge characteristics do I select? I’ve set it mli setting for now as that seems the closest to lithium settings smart lithium
Settings for Voltage: Bulk / Absorption should be a few 100mV less than the battery maximum voltage, float can be ~0.25V below that, or according to the battery specs. Max charge current for the battery should also not be exceeded.
