Hello, I had the Cerbo GX installed into my 5th wheel RV. Everything worked fine as far as being able to access all of the data from my phone on the VRM. First, I didn’t have the touch screen installed but plan on doing that at a later date. The Cerbo was installed three and half hours from my residence and like I stated all was well. I get home and try to connect to my wifi (star Link), and the curb will not connect to the wifi via my phone or from my computer. What am I missing? How do I get my phone and Cerbo connected so I can see all of my solar information? Thank you for any assistance.
WiFi access point LED on the Cerbo should be flashing…
Can you see the Accees point of the Cerbo on your phone’s wifi settings? if not:
you will need a laptop and ethernet cable:
Connect the laptop to the ethernet port of the Cerbo. try and access “venus.local” in your web browser.
then go to settings>Connectivity>Wi-Fi to see what Wifi networks are listed
I was able to attach using the Venus access point. Just when I attach the settings cog disappears and I can’t log onto my home wifi.
settings cog and bottom menu bare are auto hide, if you click a mouse on the screen, they should re-appear.
