Cerbo GX will not connect to Marina WIFI.
Can connect to marina WIFI with a phone or laptop.
Tried a known good Cerbo GX and it will not connect either
Here is the WIFI data displayed on laptop.
The Cerbo can only connect to 2.4Ghz networks natively, it can’t connect to 5Ghz networks as you’re showing there.
Thank You Justin.
I now understand that I need a dual band WIFI repeater, capable of “bridging” a 2.4 GHz device to a 5 GHz WIFI network, correct?
That seems like it might work, but I wouldn’t comment on that as I’ve never tried it. If a router is onboard, presumably picking up the marina wifi, you could just connect the Cerbo via Ethernet to the router and that would resolve the issue; likewise if you had a repeater with an Ethernet-out, that would also resolve the issue.
Ahhh, connect CERBO via LAN to 5 GHz WIFI router. Even better. Merci
