Cerbo GX Stopped Working with Victron Connect
My Cerbo GX has been working flawlessly for the past year, but after connecting the display unit, it began going offline periodically. Removing the display unit did not fix the issue. The display was the only new device introduced to my setup.
I observed that the first issue is that devices disappear from the Devices tab and eventually go offline while using the VictronConnect app. Remote reboots do not restore the devices. When I access the Cerbo GX locally, I see the devices using the VRM Portal.
Only a hard restart restores the list of devices and remote access, but then the pattern repeats of losing the devices and access.
Is this a known problem with a fix, or is the unit damaged?
