Integrate Cerbo-GX with Wolf CHA 16 via EEBus
I tried integrating the Cerbo with FW 3.85 and the Wolf CHA 16 via EEBus.
Both sides trust each other, but then I can’t get any further: the heat pump doesn’t appear, either in the device list or under opportunity loads. Has anyone here perhaps managed to get this working and can give me a tip?
It should appear under devices, its not controllable yet, it will only show load
So opportunity loads is not possible, thats a feature still in development
I have no wolf heatpump but a bosch
Thanks for your reply, Marc. Unfortunately, it doesn’t appear there… These are all the devices I can see.
@citolen nils, maybe you can help?
Indeed, we are happy to investigate further.
@ChrisBe I’ve sent you a private message.
I’ll update the thread once the issue has been identified.
The issue has been identified.
The root cause is a casing mismatch with the device’s SKI.
It was one of the known issues, a fix for this is ready and already planned for a future release.
