We install Victron battery systems and Viessmann heat pumps every day, so you can imagine how excited we were when EEBUS integration was introduced!
Today, we completed our first installation combining Viessmann and Victron with EEBUS. Getting the two systems connected was surprisingly easy.
In Victron, you simply enable EEBUS, and in the ViGuide app, you scan for EEBUS devices.
Viessmann discovers Venus, and Victron detects the Viessmann heat pump.
However! The connection doesn’t seem to be stable, or perhaps Victron is polling too frequently?
Please see the video below showing the issue we’re experiencing.
citolen
(Nils)
2
Hi Kevin,
Thank you for the detailed report.
I’ve sent you a private message, we will help get to the bottom of the issue.
I’ll report back on the thread once the issue has been identified.
Hi nils, i have a similiar issue with a bosch 5800iaw
Cerbo connects to heatpump and the other way round, but heatpump continues to give an error
Error 1240 comms lost between energy manager (cerbo)
citolen
(Nils)
4
Hi Marc,
Thanks for the report, I’ve sent you a private message, happy to help investigating why it’s not successfully connecting.
I’ll report back on the thread as well once we’ve identified the issue.
citolen
(Nils)
5
The issue with the Bosch 5800iaw heat pump has been identified and will be fixed in a future release.
The connection is successful and the heat pump is reported on the GX device, but error 1240 would be shown on Bosch’s side.
The issue is unrelated to the original topic’s issue with the Viessmann Vitocal which is still under investigation.
