Cat-6 cable connection pinouts
I am enquiring if you can help me on the cat-6 Ethernet cable connection between the can port of the VM-3P75CT energy meter and the Waveshare Can_Hat attached to the Raspberry Pi 4. At the moment, my system is working with CG ET112 energy meter with an RS485 to USB cable and I have no issues except that this meter is slow. I am in the process of replacing the ET112 with an VM-3P75CT. Can you please guide me on RJ45 colour pinout sequence on the VM-3P75CT VE_can port via a 20meter cat-6 cable to the Waveshare can port pin out? Thanks.
victron ve can pinout is
3 gnd, 7 can H, 8 can L
That is on an normal rj45 cable:
GR/W, BR/W, BR
