How to wiring RJ45 for devices?
I’m working on the electrical system in my vehicle and I’m wondering about the RJ45 cable configuration for Victron devices?
I’m going to install a digital multifunction control, so I’ll be using the RJ45 cable, but I’d like to know how the connection works. Is it a standard, simple connection like at home?
Thank you
The Victron V.Can cable are basically cat5 with RJ45 connectors. They are used for CAN-bus communications between Victron devices. Read the manuals for the devices you are connecting. Some require terminations. Also, take a look at VE.Direct cable options. These will plug into a GX device also and may be better in some scenarios with some devices.
If you are just using it for the Digital Multi Control to an inverter/charger simply plug it into the inverter and into the control. Nothing special.
Thank you very much for your reply. Here I’m referring more to the cable diagrams to follow; diagram A and B are different, and they are either straight or crossed, as shown in this photo. I don’t have all the devices yet. I have only CAT7 cable, i think this is OK too
the wiring should be straight, not ctossed
It doesn´t matter if you use A or B - as only orange and green is swapped - but same on both ends
The signal won´t see the color of the cable…
Victron need the straight cables, not cross over. (Cross over is used a.e. between routers, if the interface cannot configured.)
i´d better say was used
I can´t remember any Ethernet device in the past 20 years that needet a crossover cable
Yes, modern devices can configured or they auto detect the pins “Auto MDI-X“.
Some Telekom routers…
Hi everyone,
Okay, so I understand that a straight connection is necessary, and that it only uses terminals 1 and 6, so just two wires, is that correct?
VE.Can uses for example 6 pins.
Search the inet after: Technical-Information-Data-communication-with-Victron-Energy-products_EN.pdf
This describes the cabling more.
Quelle: Victron Energy
