Our caravan (Adria Isonzo) had a PSU (PS167 10A) that charged the battery and ran the 12v system from mains hook up. It started smoking so clearly needs replacing so I’ve got a Victron IP22 20A.
The PSU was only connected to the 12v fuse board so I assume that I can just connect the IP22 using the same wiring? The supplier said we also needed to run 4mm wires directly to the battery but my logic suggests that is incorrect??
Also, should I use the Victron in charger or power supply mode? Note that we are on a seasonal pitch so on mains hook up 95% of the time .
I’d be grateful for advice
Thanks
Pic shows PS167 that just has mains power and the red & black wires connecting it to the 12v fuse board
