User is using token.
Can login to VRM using this token but can’t login to mqtt: mqtt47.victronenergy.com using “Token token” as password.
Error: Connecting with MQTT server failed (NotAuthorized).
Why?
Should the access token be used as a password for MQTT login?
If so, I face the same issue. When logging in I receive the status code 5 which means - Connection refused: not authorized.
Did someone come up with the solution?
I use the token generated at the vrm portal → preferences → integrations → Access tokens
@lxonline I use the username and instead of the password I use the token. I need it for my website for the Victron management so that users won’t share the credentials
