Connect on Fedora Linux desktop, authentication problem
Yes, I know you all use Fedora Linux. Have you managed to authenticate with it?
Clicking the SIGN IN TO VRM should probably do something with browser, but nothing happens. Bluetooth sees something, but that’s it.
I tried so far that it has nothing to do with the SELinux. Apparently something with the way it got installed (AppImage)-
https://www.victronenergy.com/victronconnectapp/victronconnect/downloads#victronconnect-downloads
IMO it should be in proper DNF-repo and get installed and updated as usual.
Im also struggling to login to VRM, using VictronConnect 6.07 on Debian 12.
Clicking on the VRM tab and then on “Sign in to VRM” it opens the login page of VRM in the browser as expected, when clicking on “Authenticate VictronConnect” nothing happens.
Ive tried it using Firefox 115.12.0esr, no login possible.
Chromium 121.0.6167.139 asked me once for permission to send data to VictronConnect, but also here, VC didnt receive the data i assume.
Inspecting the page console i can see that it launched an external handler using a url including my VRM user id and a token, it also got
angular.js:15697 An error occurred while retrieving token.
t
code
"messaging/token-subscribe-failed"
message
"Operation is not implemented, or supported, or enabled."
stack
"FirebaseError: Operation is not implemented, or supported, or enabled.\n    at https://vrm.victronenergy.com/js/chunk-vendors.04db1f03.v1.js:140:7407"
[[Prototype]]
Error
and
Failed to load resource: the server responded with a status of 501 ()
I’ve looked at the app image, it appears to want to use chromium.
I have the same issue on fedora Firefox. I can log into VRM, but it fails to pass the authentication to the app image.
After manually linking the internal binaries to fix the header, bluez can connect via Bluetooth.
So between Lan and Bluetooth it’s all functioning except VRM.
