Too many requests. Please try again in a few minutes (1512)
Since yesterday, I’ve been receiving the following message when trying to log in after switching to two-factor authentication using Google Authenticator.
I’m logging in on a desktop computer using the Chrome browser at the URL:
:link: https://vrm.victronenergy.com/login
Interestingly, the app on my phone, connected to the same network, works just fine.
Is anyone else experiencing similar issues?
Hi Piotr,
We see a lot of requests from the SolarStation integration you are running. This is causing our ratelimiting to block you, which is done based on IP address. This in turn blocks your VRM access on your desktop.
After disabling that integration and waiting for an hour or two you should be able to log in again!
With kind regards,
Jarco
But SolarStation is only querying the VRM API once every 5 minutes, which shouldn’t be causing access blocks according to the VRM API terms:
“Most endpoints are by default rate limited with a rolling window of max 200 requests, where every 0.33 seconds a request gets removed from the rolling window.”
(Source: https://vrm-api-docs.victronenergy.com/#/)
Would it be possible to add my IP address (home static IP) to the whitelist?
I suspect that because I have a static IP, your system is flagging or rate-limiting it.
Hello, I am also having this issue, where I am doing a data query via the api every 5 minutes, but getting blocked.
I had left it on over the weekend, and it recovered after 11-12 hours each time it got blocked, but then the lockout triggered again the next evening.
As I am trying to build a remote alerting system for our upcoming fleet of devices, some clarity around the restrictions would be appreciated :slight_smile:
Regards,
James H.
Yes same issue in 2026 why victron, i am a installer and i cant acces my clients.?
