Can I leave a spare phone at home to use as a gateway to VRM?
can I leave a spare phone at home, connected to my local MPPT via bluetooth, and use that as a gateway to access VRM remotely while I’m away from home? I know a Cerbo GX is what I’m supposed to use for this, but trying to save some money.
Thanks!
No, you can not interface into VRM like that.
What I believe you can do is leave a spare phone at home with the VictronConnect app to connect to your mppt via Bluetooth and have a remote access service / app set up between the spare phone and main phone such as TeamViewer so you can check on your mppt remotely.
Other apps may be available.
You’re probably better off with a raspberry pi and a USB to VE.Direct cable.
sounds like I need to figure out how to do that.
You can start here. Good luck!
…I ended up just returning the Victron MPPT and decided to go with an Ecoflow setup. no need to use a rasberrypi with that :slight_smile:
