I’ve just finished wiring up my leisure battery system with a victron smart 12v 30amp non isolated charger.
When I go to the app to setup as stated in the instructions, I go to connect via Bluetooth and it keeps saying incorrect pin even though I have used the supplied pin on the sticker and tried 000000.
I then tried to reset the pin using the PUK code, which then also said “wrong PUK code” I have tried both steps 10’s of times with the same outcome each time.
Phone has been re-settled, app reinstalled multiple times, still no luck. Has anyone had a similar problem?
All serial numbers match on stickers and in the app, all the pin and PUK numbers match. But just refuses to connect. I put in the pin, it loads to 80% then goes back to the pin input screen. Pin reset using the PUK code says “wrong PUK code”
