entity_id,state,last_changed
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:00:00.000Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:22:36.162Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:22:57.162Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:23:08.152Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:23:13.156Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:23:51.151Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:23:56.152Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:24:01.155Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:24:12.153Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:24:17.154Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:24:33.153Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:24:39.155Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:24:45.152Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:24:55.149Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:25:01.150Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:25:11.151Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:25:17.155Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:25:22.147Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:25:33.149Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:25:38.159Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:25:43.149Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:25:49.146Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:25:54.149Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:25:59.150Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:26:05.159Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:26:10.153Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:26:15.146Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:26:26.146Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:26:31.145Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:26:41.142Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:26:46.141Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:26:52.148Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:26:57.147Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:27:02.144Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:27:08.151Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:27:17.144Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:27:24.143Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:27:33.144Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:27:39.154Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:27:44.146Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:27:49.143Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:28:00.143Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:28:05.141Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:28:11.143Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:28:16.141Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:28:21.136Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:28:27.136Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:28:31.136Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:28:37.142Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:28:42.138Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:28:47.142Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:28:52.142Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:28:58.140Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:29:03.142Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:29:14.146Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:29:19.142Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:29:29.136Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:29:34.138Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:29:40.148Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:29:45.138Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:29:50.139Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:29:56.138Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:30:01.135Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:30:06.132Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:30:17.133Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:30:22.131Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:30:27.130Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:30:33.135Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:30:59.131Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:31:05.134Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:31:15.129Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:31:21.134Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:31:31.130Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:31:37.135Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:31:53.145Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:32:03.131Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::10,2026-01-02T17:32:09.131Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:32:14.127Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:32:25.127Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:32:46.129Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:33:22.130Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:33:27.127Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:33:32.125Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:33:38.301Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:33:53.119Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:34:09.120Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:34:19.119Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:34:25.122Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:34:30.125Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:34:51.124Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:35:01.122Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:35:06.118Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::10,2026-01-02T17:35:12.117Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:35:17.124Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:35:22.119Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:35:28.129Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:35:33.126Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:35:44.117Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:35:49.115Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:35:54.113Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:36:00.117Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:36:05.115Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::10,2026-01-02T17:36:41.119Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:36:47.122Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:36:52.114Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:36:57.116Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:37:02.130Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:37:13.117Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:37:23.113Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::10,2026-01-02T17:38:11.108Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:38:16.114Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:38:32.112Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:38:37.111Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:38:52.105Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:39:03.106Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::10,2026-01-02T17:39:23.107Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:39:34.102Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:39:45.111Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:40:01.107Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::10,2026-01-02T17:40:26.104Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:40:32.107Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:41:29.100Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::10,2026-01-02T17:41:34.097Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:41:39.099Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::15,2026-01-02T17:41:45.102Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::12,2026-01-02T17:41:50.103Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::10,2026-01-02T17:42:00.103Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:42:05.098Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:42:11.100Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:42:26.102Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:42:36.095Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::16,2026-01-02T17:43:02.103Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:43:08.208Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:43:18.103Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::09,2026-01-02T17:43:28.100Z
sensor.victron_mqtt_c0619ab7be9d_battery_512_battery_min_voltage_cell_id,00::08,2026-01-02T17:43:44.099Z
