Can I link 4 0-190 ohm water level sensors to it? I’m confused by the fact hat it has 2 externally powered ports and 2 other ports.
I’m planning to connect it to my Raspberry Pi 4 running Venus OS.
My boat is 12V. I’m thinking about these sensors:
No you can not, the GX tank 140 is for voltage (0-10V) or current (4-20mA) based sensors.
The solution that Victron have for resistance based sensors is the tank ports built into the Cerbo GX.
thank you. Back to the drawing board I guess ![]()
