I find the product difficult to use. The only tank sensors that are easy to obtain are resistive. I need to use a converter BEP 600-TLM-SIF Tank Level Monitor Sender Interface Module for every input.. This takes resistive sensor and gives a 0-5 volt output to Tank 140. I wish Victron would correct the Tank 140 to accept resistance sensors. The cost is very high to use the Tank 140 option.
What GX device do you have?
The Cerbo GX has 4 inputs for resistive sensors, the Ekrano GX has 3.
I have 7 tanks to monitor. Four use the Cerbo GX Mk2 and added Tank 140 for the other three.
Yes it would be good if Tank 140 was for resistive sensors. Four tanks fuel ; three tanks water.
add another cebo gx to give another 4 resistance levels. configure new cerbo to be off line…it’s in the cerbo manual
