Hello, this is my first post here..
I have an old Dethleffs globetrotter sd 1987.
I have moved away from the electroblock and installed a new victron setup.
Now im fiddeling with the tankmeter wich is original, i have no idea of wich type of messurement the tanksensor use.
It is a very basic full-medium-empty meter originally via the controlboard.
I hooked the cables to the cerbo gx tank inputs and tried different mv settings.
It seems it reads around 380.000mv but it only goes to 300.000mv
Also im not sure wich wire that goes where, i tried switching the cables but no result.
Does it mean it won’t work?
