Hi, Have looked everywhere online and have not been able to find anything on the subject. I would like to connect my tank sensors to a venus os running on a PI. Can anyone provide how this is done? Thanks
The GX Tank 140 plugs into the USB port on the pi, people have said this works. The GX Tank 140 is for voltage or 4-20mA signals from the senders. Read the GX Tank 140 manual to see how to se up sensors.
However, if you have resistive signal senders then these do not connect to the GX Tank 140 and you would need to look at another solution. These do not connect to the GX Tank 140 because the Cerbo GX reads resistive signal tank senders.
