Hello everyone,
I’m Dirk, and I’ll soon be getting my new caravan, so I’m already starting to plan the off-grid setup. It’s probably all a bit over the top, considering everything I want to install, but hey, I enjoy this sort of thing. I’m hoping I might be able to get some advice here in case my plans aren’t entirely correct or there’s a better way to put them into practice.
So, what am I planning? I want to make my new caravan so self-sufficient that, when I’m away, I can run the coffee machine and perhaps even switch on the air conditioning.
To do this, I’d like to install a Victron MultiPlus II 12/3000/120 in the caravan. For storage, I was thinking of using two LiFePO₄ batteries (12 V, 165 Ah, 200 A BMS) connected in parallel. The display and so on are obviously part of the plan too, but for now I’m mainly concerned with the wiring, specifically the cable cross-sections and fuses.
Why do I want to install a MultiPlus at all? Well, in the past it has happened a few times that you only get 6 A at a campsite, which isn’t very much. That’s why I’d like to install the MultiPlus: I can limit the input current (shore power), protecting the campsite’s circuit breaker from tripping, and if I do need more power, the MultiPlus can draw on the batteries as well.
So, here’s my plan:
The two batteries mentioned above are to be connected in parallel. I would first run cables of the same length from both batteries to a busbar. The cable cross-section from each battery to the busbar would be 70 mm², with the length being less than 1 metre. Each battery would be protected with a 250 A MEGA fuse installed shortly after the positive terminal.
From the busbar to the MultiPlus, I would use either 95 mm² cable or, as Victron specifies in the manual, 2 × 50 mm². I would protect this cable with a 350 A fuse installed shortly after the busbar; this run will also be less than 1 metre long.
The caravan’s standard 12-volt supply and the mover would also be connected to the busbar, but I don’t want to consider those components here.
So, my actual question is: are the planned cable cross-sections and fuses for the battery → busbar → MultiPlus connection OK, or should I use smaller fuses or change the cable cross-sections?
Thanks for your help.
Best regards,
Dirk
