I have been trying to get my Android tablet to connect to the Cerbo for the Android GX display to work, and it doesn’t / won’t no matter what.
I did the factory reset on the android tablet (Galaxy Tab A8) and used the QR code. The Cerbo and the tablet are on the same 2.4Ghz network. I get the black screen saying Victron Energy Loading….
Security settings on the Cerbo are set to the weakest. It’s been re-started. I tried enabling the Cerbo’s network and connected the tablet to that. Same thing. The Cerbo has the latest firmware.
At this point, I think I’ve tried everything I can think of. It must be a problem or setting on the Cerbo, I would think, given that neither the tablet nor the laptop can connect to the remote console through the web browser.
You first tried connecting over your home Wifi, so the Cerbo was a client connected to your home wifi, as well as the tablet? Are you sure that 192.168.10.64 is the correct local IP?
And then you also tried by enabling the cerbos own access point, with the tablet connected to the cerbos own wifi as a client?
And both times you were able to select the cerbo as a target in the dropdown menu, in the Android GX setup menu?
Do you use VRM, does the remote console work there?
I also had some issues connecting an old phone to a cerbo once, but using the cerbos own access point. It used to work fine at first, but when the phone was switched off and on again, the connection failed, but i cant remember if it was getting stuck on the same black loading screen. Essentially i switched the phone, it had some issue re-establishing the connection after a restart i assume
I think I’ll give up on it, not sure it will ever work given the effort I’ve put into it. I even made a separate 2.4Ghz only network for both the Cerbo and the Tablet to connect to. Still no dice. But thanks for looking into it for me!
Came here with the same problem. It all works fine until the tablet needs a reboot and then nothing works at all, no menu, no config it’s a brick. All I can do is wipe and rebuild the thing then set it all up again.
I’ll scrap this gimmick idea and buy the proper kit for it instead.
I went with Andreas solution above. Just open a browser and access it that way. Set the browser to use that as the home screen. It’s unfortunate it doesn’t work the way it was designed to.
Hiya, yeah I could do that. I also tried letting the tablet set itself up and then configured the browsers home page, (which worked) but this is on an off grid van build and I have no shred of a doubt that I’ll have to become a software engineer the first time I try to check my battery in a field somewhere.
I managed to get it to work. I did nothing differently other than the Cerbo firmware has been updated sereral times since.
My guess is they updated the app that it downloads as well. In short, I guess they fixed it and it’s a better way to go then using the tablet browser. But either works, for me, it’s better to have the tablet reset and only run the interface.
