I REALLY WISH I KNEW THIS BEFORE BUYING!!
please Victron help us out, the only reason i bought this sensor was for the cerbo!!
how difficult is that? im interested!
it would be amazing if Victron could also add the temp sensor thats inside the mopeka to also read as its own temp sensor inside venus os.
maybe even the leveling sensor too?? CMON VICTRON!! then only thing thats missing on cerbo is way to hook up security cams, would be the PERFECT system. I cant be the only one.
Reached a point where the Cerbo recognizes a Mopeka Universal Sensor in the bluetooth sensor menu, but not under the device menu. @jkaufmann totally not cool that you didn’t inform the early adopters that there was and still is no real timeline until Victron integration.
I would be happy if I could use the project. How can we get together?
Best regards Uwe
Hi everyone,
Sorry, I’ve been busy lately… I’ll write a short report on the project this weekend and post it here. I’ll also try to publish the code on GitHub.
Alles weitere Dazu in der Modifications Abteilung..
Support for the Mopeka Pro 200B is added to Venus 3.80~19 beta or newer. No timeline on when Venus version this will be available.
With kind regards,
Thiemo van Engelen
Thanks for info and update. ![]()
v3.80-21 Beta installed; the Mopeka Pro 200B was found straight away and successfully added.
Many, many thanks to Victron ![]()
Thx 4 trying
Downloaded the beta firmware and also happy to report that the 200B is displaying perfectly. Thanks so much!
hi all. some kind of off-topic. what could be the reason if i dont see the v3.80-xx versions. I choosed beta FW, pushed “update” and only official releases (3,72, used the non beta option) where mentionend, but no 3.8x. any idea?
Do you have a CCGX? That model is end of life and version restricted due to limited resources.
hi nick. no, its a cerbo gx mk2 from 2025.
| Produkt | Cerbo GX MK2 |
| Firmware-Version | v3.73~1 |
This is the current beta, 3.80 is temporarily paused to get 3.73 released.
@Brekki Beta 3.73~1 also has support for Mopeka 200B listed in the changelog so you can try this one and when released stay on 3.73 official if you do not want to keep running beta FW.
it took me some restarts and also some configuration tries. No its running. looks good so far.
