Hi all,
I’m currently running a Victron system configured with Dynamic ESS (DESS) and would like to add a Victron EV Charging Station for tighter system integration instead of using a third-party charger.
I’d appreciate guidance on:
What exact parts/components I need to purchase
Whether any additional meters, GX devices, or wiring are required
If there are known issues integrating with DESS
Where the EV charger would connect within the overall system (and how it should appear in the schema diagram)
Is Victron EV Charging Station compatible with Octopus tariffs (Flux and Go given DSS in use)
Current System Overview
Inverter:
- MultiPlus-II 15 kVA (48 V)
Battery Storage:
- 3 × 15 kWh Fogstar batteries (total 45 kWh)
PV Array:
South: 10 × 470 W (4.7 kW)
North: 11 × 470 W (5.17 kW)
West: 9 × 470 W (4.23 kW)
Total PV ≈ 14.1 kW DC
DNO Export Limit:
- 12 kW
Home Annual Consumption:
- ~4,100 kWh
Questions
Do I need any additional energy meters beyond my current grid metering setup?
Do I need any additional CT clamp for the solar generation feed?
Does the EV charger integrate directly via GX device, or is extra hardware required? currently GX device is connected via WIFI and I am planing for the EV charger to use the same WIFI network.
In the system diagram, does the EV charger connect purely on the AC-out side as a controllable load?
Any advice from those running a similar setup would be much appreciated.
