Hi All,
I’m looking for a detailed guide or tutorial for setting up a MultiPlus-II GX 48/5000 (installation and configuration) for a home battery setup without solar on a single phase domestic property in the UK. I’ve seen some other similar and helpful posts, but non seemed to answer my questions. I’ve included a lot of my design and research below for anyone else considering this setup.
I want to make the most of the Intelligent Octopus Go; set the MPII to charge when the EV is charging, usually between 1130 and 0530, and discharge to feed the house during the day. There’s not real need for UPS, but that’s a nice to have. I’m not planning on exporting back to the grid.
I think I’m most of the way through designing the system, but there’s a few final bits I can’t find definitive answers for.
The basic system is going to be installed in a separate garage which has a single radial feed from the main house (and grid). I have a couple of Cat6 cables run too, one is for network / internet, the other is reserved for sense cables from the main grid in. This comes into a sub-main consumer unit in the garage. This has all been installed by an electrician who’s going to be finishing the end of this install and signing it off, he’s done the maths on cable diameters to meet regs.
I’m planning on going with a Fogstar 16.1kWh battery [1] which uses a Pace BMS (supports Victron Inverters via Victron Protocol or Pylontech Protocol[2]). Communication is over a VE.Can to CAN-bus BMS[3] Type B cable (Source: Fogstar Manual[4]). The DC side is pretty straight forward.
The Garage CU will connect to the MPII and to the EV Charger.
I haven’t found a definitive answer whether AC-IN on the MPII is bi-directional, there are a couple of comments[5] in various[6] places[7] that say it is, but the installation guide[8] seems to say that it can only be used as pass-through for grid.
As I want my entire domestic supply to be primarily served by the MPII (with grid backup in case of occasional >4000W load), do I need to connect AC-in and AC-out-1 or can AC-in provide the output from the battery?
I want to ensure that when the EV Charger is drawing load, the MPII is set to charge the batteries. Most of this is going to be done via scheduling and I know I could automate this through Home Assistant but I would ideally like something more tightly coupled. I haven’t been able to find an configuration guide on how to use a CT Clamp on the EVC radial to set the MPII to charge the batteries. Would this CT sensor be connected to one of the AUX sensor ports or the current sense port? Where can I find a configuration guide for this?
Does the rest of the design make sense? I can’t seem to find many guides or designs that don’t include solar and just rely on charging from grid at cheap rates.
Additional links as text because “An error occurred: Sorry, new users can only put 2 links in a post.”
- www.fogstar .co.uk/collections/server-rack-batteries/products/fogstar-energy-16kwh-48v-solar-battery
- www.fogstar .co.uk/pages/fogstar-energy-esr51-2-supported-inverters
- www.victronenergy .com/cables/ve-can-to-can-bus-bms
- cdn.shopify .com/s/files/1/1347/0997/files/FogstarEnergy_16.1kWh_Battery_compressed.pdf?v=1737370967
- communityarchive.victronenergy .com/questions/9317/multiplus-ii-ac-supply.html
- communityarchive.victronenergy .com/questions/239761/multiplus-ii-as-a-home-battery-for-load-shifting.html#answer-279144
- community.victronenergy .com/t/connection-question-on-the-multiplus-ii-in-a-ess-setup/15205/2
- www.victronenergy .com/media/pg/MultiPlus-II_GX/en/installation.html#UUID-b8310945-a1c7-2bfd-5f57-c494fa312015
Thanks!
