I have a Victron ESS system consisting of a MultiPlus-II 48/3000/35-32, Cerbo GX and SmartShunt.
The Cerbo GX is currently running Venus OS 3.80.
I am using a Shelly Pro EM50 to measure my AC loads. The two EM channels are used to measure two different load groups:
- Essentials
- Terrace
The measurements are available in the Cerbo GX and are shown under Loads → AC Loads.
For example, at the moment the display shows:
- AC Loads total: 315 W
- Essentials: 288 W
- Terrace: 2 W
My questions are about how these values are presented and calculated.
1. Displaying the individual AC loads in the main overview
Would it be possible for the main AC Loads box in the Overview screen to display the individual Shelly measurements, in a similar way to how the Battery box displays voltage, current and power?
For example:
AC Loads
Essentials: 288 W
Terrace: 2 W
Total: 290 W
At present I have to enter Loads → AC Loads to see the individual measurements.
Since the Cerbo GX already receives the two measurements from the Shelly Pro EM50, would it be technically possible for the main AC Loads box to display these individual loads?
I understand that the MultiPlus-II itself does not independently measure AC-Out 1 and AC-Out 2. However, in my case these loads are being measured externally by the Shelly Pro EM50, so the question is whether the GX UI could use these measurements for the overview.
2. Difference between AC Loads total and the individual loads
There is also an apparent discrepancy which I would like to understand.
In the example shown in the attached screenshot:
- AC Loads: 315 W
- Essentials: 288 W
- Terrace: 2 W
Therefore:
315 − (288 + 2) = 25 W
What does this additional 25 W represent?
Is the 315 W value calculated from the MultiPlus-II measurements, while the 288 W + 2 W values come from the Shelly measurements?
If so, what exactly is included in the 315 W value that is not included in the Shelly measurements?
3. Difference between Grid power and AC Loads
The same screenshot shows:
- Grid: 339 W
- AC Loads: 315 W
Therefore:
339 − 315 = 24 W
This is very close to the 25 W difference above.
Could someone explain what this approximately 24–25 W difference represents?
Could it be related to the self-consumption of the MultiPlus-II, or is it another calculated value in the GX energy-flow model?
4. Battery power
The battery is shown as:
- 53.22 V
- −0.3 A
- −15 W
Could the approximately 15 W shown here be the DC power being consumed by the MultiPlus-II itself?
Or does this value include other system consumption/losses?
In other words, is there a specific GX/VE.Bus value that represents the actual self-consumption of the MultiPlus-II, separately from the AC loads?
I would mainly like to understand how the GX calculates these values and why the individual Shelly loads do not add up to the AC Loads total.
Thank you.
