Joeelb
(Joeelb)
1
I have a Pylontech battery connected to CAN 1 and a JK-BMS battery connected to CAN 2.
Serialbattery and batteryaggregator are installed. Only one battery is ever visible in the device list.
When I press “Redetect battery”, the same one appears again or it switches.
The aggregator isn’t visible in the device list either.
Both batteries are visible in the Ekrano’s device menu. Both are on instance 512.
Where’s the problem?
Which protocol should I use in the JK-BMS?
I’d be grateful for any advice.
Regards,
Jörg
nickdb
(Nick)
2
Moved to modifications.
Just a reminder pylontech will void your warranty when you mix unsupported batteries on the same system.
For debug can you test only one battery at ones.
Have you configure Serialbattery
My config (I have 2 JK-BMS on can port)
Joeelb
(Joeelb)
4
I had tried that before too. I’ve now added this to config.ini.
BMS_TYPE = Pylontech
BMS_TYPE = JKBMS
POL_INTERVAL = 2
CAN_PORT = vecan0 ,vecan1
No change.
Joeelb
(Joeelb)
5
Hi Fredd,
Do both batteries have the same instance? 512?
I added the entries as described and reinstalled the Battery Aggregator.
Both batteries and the Battery Aggregator are now visible on the Ekrano, and I was able to select the Aggregator as the controlling BMS.
Regards,
Jörg
Joeelb
(Joeelb)
6
Hello Nick,
Thanks for the heads-up. I have 14 batteries from 2019. They still have a state of health of 97%.
The warranty has expired anyway.
Best,
Jörg
nickdb
(Nick)
7
Warranty, when you register, should be 10 years.
Joeelb
(Joeelb)
8
Yes I know, but I have register only 6 Batteries .I think that is no problem that they work the next 3 years.
