180kva System - Unspecified system shutdown -
Dear Community, We have installed a gridconnected 180kva system in Albania, consisting of 12 pcs. of quattro 15000Va (4 on each phase) System has been running with no problems for a week, then with no specific reason the system shuts own in the middle of the night with these errors. Do you have any suggestions why this is happening.
I have many years of experience with building Victron systems, and I am a fan of the brand compared to others. This is the first time building a system of this size.
Battery cables are all same length :slight_smile:
Thank you all in advance
@Lasse123 Worth looking at the ripple numbers using the widget and detailed view. At a glance DC cable length and possibly guage which be my first concerns. You may want to consult with another Victron installer, off such large systems, to get a second opinion.
Take a look at the docs. There are troubleshooting steps. Seems most likely an issue with the communication cabling. Error 17: VE.Bus Error Codes [Victron Energy]
I think of spikes on the grid is the cause.
Maybe … Error 17: Phase master missing
But the system should protect the compound by throwing the grid, if it falls outside the bounduries?
