kallenr avatar image
kallenr asked
option to disable 'ac loads' display
With an ON-GRID ESS system, the 'ac loads' display will not be correct if you do not have a solar meter installed.
However, the installation works perfectly, because it is based on the set point of the grid meter.
Is there a possibility not to display the AC loads?
ESS
