bahama avatar image
bahama asked
ArgoFet LED
I installed an argofet 200-3 on a houseboat
-wired the input from the alternator to argoFET input
-connected started battery to #3 output and house and generator batteries to #2 and #1 output.
Blue LED was on first couple times I ran the engine. now the LED is off. does that indicate batteries are charged or does the LED indicate nothing useful in particular?
-voltage on the input is 4V with engine off and 14.6V when running.
-voltage on all the outputs is 14.6V when running and then shows battery voltage for each battery when engine is off (13.2 V, 12.8V etc).
thx
Argo FET Diode
