ScottR
![img-2381-7.jpg](/storage/attachments/22259-img-2381-7.jpg)
ScottR
I have another job using the same type of controller, SmartSolar MPPT 150-45Tr.
Same issue, Programmable Relay set as "Load output" switches at half of the "Load Output" Set point voltages (only for Load Output where it measures Battery Voltage, it switches at the correct setpoint voltages for PV voltage if using the StreetLight Function).
Controller was updated to latest versions during programming.
My Guess is that all of this model controller will have this issue.
Victron if you are reading this, you need to look at your firmware.
WARNING : for anyone using this controller expecting the programmable relay (when set to "Load Output") to operate from the "Load Output" settings, it will switch at half of the Set "Load Output" Voltages.
Your only solution will be to use a separate Battery Protect unit and use whatever (limited) settings are available in it.
Regards
ScottR
30 People are following this question.
