I have two Siemens panels from 2005-ish (they came with the barge) connected to a 24v system thru a BlueSolar MPPT 75/15. I would like to increase our solar charging capabilities. Will adding new panels to the existing system cause problems?
"it depends" I suggest that you supply more information to get the best answer. Data such as the current wiring configuration (series or parallel) volts, amps and wattages of the current and the proposed panels. In the meantime consider that your current charge controller can only put out ~360watts of solar (24 volts x 15 amps) but more solar than that will not damage it as long as you don't series the modules past 75v.
33 People are following this question.
