oleg1984 avatar image
oleg1984 asked
Setting up the ESS in a three-phase system
We use a grid parallel 3-ph system with 3 Quattro-48 10000-140-100/100 inverters and 4 Smart 25.6V-200Ah batteries. What is the ESS setup sequence in a three-phase system? According to the instructions, you first need to configure a three-phase system, in our case using VE.Bus Quick Configure, after which, using the VE.Configure program and the MK3 adapter, you need to add ESS in the inverter settings. The problem is that it is impossible to enter VE.Configure with a three-phase system setup (when trying to log in, the system writes-it is impossible to connect to the inverter, because it is not configured in stand alone mode
ESS
Alexandra avatar image
Alexandra answered ·
@Oleg1984
Set yourself up with a Victron Professional account. You need more training
It is free there.
