manfred70 avatar image
manfred70 asked
no ESS Assistant found on V2.72
Hallo, hope sombody can help me.
I have done a softwareupdate to my MultiPlus-II 48/3000 GX, to V 2.72, now the is no ESS Assistand found.
VE.Bus Version 2629485
VRM Instance 275
Firmware version 2629
do you need more detail?
Kind regards
Manfred
ESS
Alexandra avatar image
Alexandra answered ·
@Manfred70
Whenever firmware is updated the settings are wiped and device reset to factory.
You need to reprogram your inverter, or reload your saved settings.
https://www.victronenergy.com/media/pg/VE.Bus_Configuration_Guide/en/firmware-updates.html#UUID-ffb3824e-89bc-2ffa-b183-d04c22757bad
manfred70 answered ·
Thank you, I will organize a MK3 to USB
