Newby question, I have MPPT 75 on a solar panel, do the watts displayed when battery is full and in float mode go down?. Ie does the controller reduce the watts displayed? Leisure is full, really bright sun reading 7w? Thanjs
Yes, you should expect low solar yield when the battery is full and there are no loads on the battery. This is because there is nowhere for the power to go anymore.
If you put a load on the battery and there is sunshine, then you will notice the power increase to satisfy the load.
I'm seeing the same thing, when the battery is full, my reporting is inconsistent.
If younthink there's a problem, please start a new thread, giving battery details, charger screen shots and a clear description of what concerns you.
31 People are following this question.
