Is there a way to have loads that are grid connected only but still monitored through the VRM, I tried putting the loads after the external energy meter on the grid side but the multi is still feeding them from the battery.
markus, i want some of the loads to be fed from the grid directly due to high start up currents outside of the multiplus limits, i would also like to limit any unnecessary drain on the batteries, my understanding is as normally there would be grid available all the time on the AC-IN1 any loads on AC-OUT2 would still be fed from the batteries until the total load is outside the battery discharge limits or if the grid fails.
40 People are following this question.
