skillenes avatar image
skillenes asked
My smartsolar didnt start charging
My smartsolar 150/85 didnt start charging in the morning. I must turn off "charger enable" and turn it on again before the smartsolar start charging. PV voltage is aboat 70 volt and battery soc is about 80%. I have another smartsolar 100/30 in the same system but this operate perfectly. This have no happend the last two days, it have been istallaled a year ago and there have been no problem earlier.
MPPT SmartSolar
4 comments
Have you compared the history between your 2 mppt's?
Esp have a look at the battery min/max voltages.
skillenes avatar image skillenes klim8skeptic ♦ commented ·
Yes, the battery min/max voltage are almost the same, the biggest differense is 0,03 volt at min voltage and 0,01 at max voltage. There are some differense in float/bulk time between the mppt, but they handdle pv panels on two different walls (south east and south west)
klim8skeptic avatar image klim8skeptic ♦ skillenes commented ·
Normally to reboot an mppt you would disconnect your pv array then the battery for a minute. Then reconnect the battery then the pv array.
Most problems with mppt's come from bad fuses or bad wiring/connectors.
Ok I must try to reboot the mppt next time I go to my cottage. Wiring, connectors and fuses seems to be ok
