westen avatar image
westen asked
triggering a relais when sufficient power
My system: smart MPPT 100/50, smart BMV512, smart Batteryprotect (the big one), 12V system, batteries AMG 690AH, solar 500W functional.
I'd like to run a pump on solar during summertime (for a pool).
I'd hate to drain the batteries though.
Any relais in the system I've got that can help out here?
any advice welcome,
Jan
MPPT SmartSolar
Alexandra avatar image
Alexandra answered ·
@westen
The relay at the back of the BMV 712 - is programmable, (easily set using Victron Connect) you can set it to open or close on certain SOC settings. Be aware it can only switch up to 1 Amp
https://community.victronenergy.com/questions/2450/we-can-not-find-any-detailed-electrical-specificat.html
So it would need to trigger a contractor for the load not run it direct.
westen avatar image
westen answered ·
Thanks Alexandra.
You've given me a starting point.
I'm going to look into this.
