linda28 avatar image
linda28 asked
SmartSolar 100/15 compatibility with 125W panel
  • Hi there,
I have a basic question to ask before I buy a SmartSolar MPPT controller for my solar panel.
I have a 124.5W solar panel
Specs here:
Voc: 24.48V
Isc: 6.32A
Vmp: 20.88V
Imp: 5.97A
Ptol: +/- 3%
Power
124,5 W
Pmax - Maximum achievable power
124,5 W
Voc - Voltage open circuit
24,48 V
Isc - Ampere short circuit
6,32 A
Vmp - Voltage maximum power
20,88 V
Imp - Ampere maximum power
5,97 A
I was was wondering if I can use a 100/15 solar controller rather than a smaller 75/10 as I will maybe add another 124.5W panel in the future.
I know a 75/10 would be proficient but I was wondering if the 100/15 will still work ok with just a 124.5W panel.
(The nominal PV power at 12v of the 100/15 controller is 220W and nominal PV power at 12v 75/10 controller is 145W.)
Does the nominal PV power have to be close to the power of the solar panel for it to work correctly.
Apologies I am new to this and would really appreciate before I buy the 100/15 controller just to make sure it will work ok and isn’t to powerful for just the 124.5W panel.
It says in the SmartSolar manual:
“PV array too small”
“If the PV array power rating is less than the solar charger nominal power rating, the solar charger cannot output more power than the connected solar array can provide”
Many thanks
Linda
MPPT SmartSolar
Alexandra avatar image
Alexandra answered ·
@Linda28
The 100/15 mppt will work with your panel quite well on a 12v system.
Your mppt will be able to output the max of the panel which is the 125W. The warning in the manual is rather stating the obvious that you cannot get out more than you put in if it less than the 20A at 12v which is 240W
linda28 avatar image linda28 commented ·
Thank you Alexandra I appreciate your answer. That’s great I will buy the 100/15 and this will future proof me if I get another panel. :)
